What's your current hardware build?
- stormsonweathers
- Contact:
As the title implies (and to restart posting on the forums) what is your current daily driver? Is it a modded workstation from Dell or HP? Or is it a custom build?
Re: What's your current hardware build?
Dell Precision T5810 with Xeon E5-1650 V3, 32GB DDR4 quad channel, 685W power supply, Sapphire Pulse RX 5700 XT, 1TB Teamgroup SSD, Windows 10 Pro.
CPU is overclocked using Throttlestop to 4.3Ghz @1.16v 139.1W at 100% usage avg 60c gaming with stock cooler.
GPU is undervolted with TDP limit increased to 250w, core speed 2100 @1150mv, and memory at 1800mhz.
Stock cooling with fan bios settings on +20 due to heat created by the gpu.
Planned upgrades are vertical mounting the GPU to give more clearance from the side panel and better air flow and rear 92mm exhaust fan.
Also looking at custom 3d printed adapters to allow mounting of commonly available heatsink on the 2011 narrow ILM platform. Possible AIO installation for when it’s time for bigger OC.
- stormsonweathers
- Contact:
Because of my work keep me on the move, I'm using a Dell Precision 7710 mobile workstation.
- 64GB of RAM
- 8x (4 threads, 4 cores) Xeon E3-1535M @ 2.90Ghz
- 1 Intel Optane H10 NVMe at 256GB (using a Dell 2 lane PCIe NVMe adaptor for the onboard SATA port)
- 1 Fanxiang S500PRO NVMe at 2TB
- 1 Western DIgital Green SN350 at 1TB
- 1080P screen
- Nvidia Quadro P3000 Mobile
- OS Manjaro Linux (primary), Windows 11 (secondary)
- 64GB of RAM
- 1080P screen
This is my third HP z Workstation build and sheesh these things are definitely the goat!
- Attachments
- Screenshot (7).png (173.44 KiB) Viewed 53719 times
- Screenshot (4).png (247.19 KiB) Viewed 53719 times
- stormsonweathers
- Contact:
That's some nice specs!LoLLess wrote: Mon Mar 06, 2023 10:29 pm This is my third HP z Workstation build and sheesh these things are definitely the goat!
Hmm, my Z840 has 2 x 2699s in and it's only reporting as "Gaming 40%" (but that may be the GPU - Quadro not GTX).
CPU getting 61/62% and only seems to test one socket?
I've just removed the Quadro M5000 from my box and replaced it with an RTX A4000.
Half the height, less power consumption, more clout
- stormsonweathers
- Contact:
Cool! Be interested to see what numbers can produce! I'm still on a RX 5700 XT since I don't use my desktop like I used to
Which tool would you like me to run to get a number?
- stormsonweathers
- Contact:
Timespy would be a good one to get gaming related numbers and Cinebench for overall testing.
